First season maintaining my pool myself. Main issue: will not ignite/fire.
Running a Pentair Mastertemp 300.
Opened the pool and started up the heater.
The blower went on but never fired. And a very funky smell from the exhaust! Equal to the funky smell from the entire insides once the cover was removed
No error codes just the red service light.
Opened up the unit and found a massive mouse nest on the heater and baby mice inside the heater box.
Cleaned everything up and same result. tried to check the wires is all looked good.
Now... I may or may not have dropped the top cover at one point. And since then the display (temp display) started working intermittently then not a all. All the indicator STILL work, but the LCD display is not longer working but the unit still starts up and still tries to fire.
Original pool Installer put a small wire screen in venturi and the plastic is clean and white so pretty sure nothing got into the blower. (shame he didn't do the same for the vents on the entire heater!)
questions
1) regarding the membrane/lcd display. Do i need to replace just the membrane, or does the the entire controller board? (no mouse destruction evidence on either.
2) what is the yellow button the controller board
3) notice rust and a water leak on the 3rd from the top and maybe 4th from the top bolt on the left side of the manifold, just about the level of the by the sensor
4) given the smell when the blower is going does that mean I am going to have to open and check the combustion chamber - and is that hard? And if so when reassembling, to I need to
questions
