Have a Mastertemp 250 that I don't have a lot of history on (came with the house we moved into last August, wasn't hooked up). Heater was setup for propane and we finally got a large propane tank setup last week. Went to fire it for the first time yesterday and the heater kicks in fine, runs for a few seconds (maybe a minute), and then as soon as the fuel ignites a high pitched squeal/whine begins. The noise is pretty disorienting so it's a little hard to pinpoint where but it seems like the exhaust or gas valve as best as I can tell. The water does heat noticeably, I can feel the outlet lines getting warm and my wife said she could feel the warm water in the pool.
Things I've tried so far:
1. Remove thermal regulator - no change in sound.
2. Adjusted flow on the pump, up and down - no change in sound
3. Checked the pressure on the front side, where the propane comes in - getting static 10 inches WC which is, as I understand, within range. Expected to and still got the noise while testing. I don't have access to a differential manometer at the moment to check backside but I'm working on it.
4. Removed the union where the orifice lies and double checked the orifice was seated correctly and is smaller than the NG orifice. Check and check but still squealing on next fire.
At this point, the ONLY way that I've been able to even dampen the noise a little is by placing my hand over top of the intake. I don't fully block the intake, only cover it enough to reduce the air flow into the system and then the scream/whine disappears.
I'm guessing this is an issue with pressure in the gas valve but I'm wondering if anyone has experienced something similar or if anyone has any idea of other debugging tools to try. Thanks in advance!
