Team TFP,
So, I read a number of threads about the Master Temp 400 cycling above a certain temperature- which is the problem that I am having. So, I attempted to remove the Thermal Regulator and see if it looked bad or reach in and see if the bypass was bad.
First error- apparently, i do not know where it is... at least on the first try. So... I ended up disconnecting some wires from the two screen in caps on the left side of the heating manifold. Then, i removed the bottom plug (HLS switch maybe??). Well, water started streaming out so i quickly put it back in.
Second issue- now knowing where the Thermal Regulator actually is, I began to take it out. But then I heard water about to start flowing out. My pump is clearly off for all of this but my hot tub/spa is raised and thus any outlet lower than it (like all the pool equipment) will let water flow continuously until the spa empties.
Two questions:
1) Now that I took out the lower plug and simply screwed it back in... will it now leak unless I seal it??
2) If I pull the thermal regulator, will water come shooting out due to the pressure caused by the raised spa? If so, how do I stop that from happening?
Please advise as before I make this worse....
As always... thank you TFP!!
Best,
Warren
Two questions:
Best,
Warren
