szobell
- Aug 6, 2012
- 14
- Plaster
- Pentair Intellichlor IC-60
Sorry you are having this problem. I had the exact same issue with my system, it turned out that the socket that the wires plug into to communicate had a broken part in the housing so when the plug was “pushed in” it wouldn’t always make a connection with the wires and that is why it kept losing connection. You could try pulling off the screws on that housing to see if you have the same issue so you don’t have a tech come out and flash your firmware only to have the issue reoccurr.
Hopefully they can get to the bottom of your issue.
