I just installed a pentair intelliflo vsf pump with my jandy aqualink rev QQ controller. Wired both poles thru the filter pump relay as the jandy manual instructs, connected the rs485 wires (pin 2 yellow, pin 3green) as the online refs instruct. Pump properly displays “display not active”, set the controller to vf pump and filtration application, scheduled the filter pump and variable speed times. Controller is communicating since the jandy onetouch displays the pump rpm, wattage, and gpm, but the controller isn’t adjusting the speeds.
Only way I can change speed is to unplug the rs485 use the pump control panel to change it, then plug the rs485 back in and power cycle the pump.
If I go into the speed adjust for the variable speed pump on the jandy controller and set a new speed it doesn’t change anything. I’ve also tried setting the pump to external control mode, and also wiring the pump direct to the breaker so it doesn’t power cycle but still nothing.
Any ideas on why the jandy controller isn’t changing the pump speeds, or the vsf pump isn’t responding to speed commands?
