Hello, I recently had a pool installed. All pentair products, and the pump and light controller were already wifi ready. My only issue has been the fact that I cannot control the heater from my phone, so I purchased an Intelliconnect system. Paid an installed to come out and hook it up, and he could not get the heater to kick on. He eventually showed it working, took my money and left.
I see now that his "fix" was to hook the firemans switch up to a relay. First of all, everything I am reading states that the fireman's switch should NOT be connected to high voltage, so I immediately disconnected that. Unfortunately when the fireman's switch is hooked to the low lever heater header in the Intelliconnect, it does not turn on. The app does not not turn on the heater no matter what temp I set it on. Not sure what the issue is. Placing the Intelliconnect into service mode and holding down both relay buttons does turn the heater on, for whatever that is worth. Any help?
