Hi Guys, I have a Pentair SWG that is no longer powering on my salt cell. I have a spare salt cell that I swapped and that did not power on. I then checked the fuse at the bottom of the power box and that was good. I used a voltmeter and check the voltage at the fuse and my reading was 32V which I'm guessing is good as I read somewhere that the transformer should be producing 25-35V. The only thing I see between the fuse and salt cell power cable connecter is a small control board that might be bad? There is a green led bulb on the board that is not lit. Before I go buy a $200 board I wanted to make sure I am not missing anything. Also, would it be worth just buying a new power generator since its only a $100 more? The current generator is about 10-12 years old. Any help would be much appreciated as I am not an expert in electrical troubleshooting.
