In the settings for my EasyTouch, I have the "Chlorinator present" set to no/off. Because I've done that, I don't have that menu option in app to adjust % etc. But when I go out and take a look at the IC60 itself, it appears the unit is operating: the % lights are flashing where I last set it, the flow light is green, and the salt light is on with a red light (which I am attribute to cold water since testing shows 3000 ppm).
So my question probably comes down to:
1) If Chlorinator is turned off, what is the actual behavior I should expect on the IC60?
2) How do I know if the IC60 is actually turned off and not working?
Thanks.
-S
Thanks.
-S
