IntelliCenter and the Amazon Echo (Alexa) app
Now that I have my AUX and Feature Circuits, Circuit Groups, Schedules and other system configurations pretty much set for my purposes in the Control Panel/Web Interface App/iOS App, I have been doing a lot of playing around with the Amazon Echo (Alexa) app lately. I have made some discoveries and I have developed a few "work-arounds" regarding some of the limitations and restrictions of using "Alexa" that I thought I would share since quite a bit of this detailed information is not found in any documentation as of yet.
BACKGROUND: The Pentair IntelliCenter Amazon Echo (Alexa) app is available for free through Amazon. You can turn on or off your various circuits (except for
CIRCUIT GROUPS presently (Please see my comments in #6 of post #29 above) like pool, spa, waterfall, lights, etc with your voice.
1. I found that naming your pool “PENTAIR” in the GENERAL SETTINGS > PERSONAL INFO will get a response from Alexa that makes sense to me anyway (“Your Pentair Pool”). Or in another example you could also name your pool “Beautiful” and then Alexa would respond with “Your Beautiful Pool ______” etc, etc.
2. At this time, you
cannot activate any
CIRCUIT GROUPS with Alexa. For example: “Alexa, ask/tell MyPool to turn On/Off “
SPA USE” (Please see my comments in #6 of post #29 above).
3. Naming conventions used for
AUX-CIRCUITS and
FEATURE CIRCUITS are very important here to prevent “Alexa” confusion.
DON’T USE ANY CONFLICTING NAMES in your Aux or Feature Circuits or it will confuse Alexa. Below are some examples.
I had my Spa Jet Pump named “Spa Jet Pump”. That did not work because I had “Spa” in the name. Once, I named it “Jet Pump”, Alexa recognized it appropriately and then the command worked. Same with my Filter Pump. I had to rename it from “Pool Pump” to “IntelliFlo”.
I also had to rename an AUX CIRCUIT from “iPH/IC-60” to “Sanitation”. This is a circuit relay that I use to provide power to my IntelliChlor and IntellipH when the Filter Pump Circuit is ON. Try saying "iPH/IC-60 to Alexa". That didn’t work out so well.
“Sanitation” works well now.
I had to rename my Spa Heater from “SPA HEATER” to “HEATER”, again because SPA was
conflicting.
4. Here are examples of how you can use the Alexa Skills. Please note that these are Skills are configured for my particular setup and the names that I have given the various AUX-CIRCUITS and FEATURE CIRCUITS are based on my personal preferences, requirements and my particular configurations and they will not apply to all pools and/or various pool equipment configurations. Some of them kind of show why you have to experiment with your particular names to get them to be “Alexa Friendly”:
“Alexa, ask MyPool what my pool status is” (Since I only have an IntelliChlor and not an IntelliChem, the response for my configuration is: “Your “Pentair” (or whatever you named your pool) Pool is currently ___ degrees and your salt level is ______ppm”. Then Alexa will list any AUX-CIRCUITS, FEATURE CIRCUITS or CIRCUIT GROUPS that are on or “running”. If no AUX-CIRCUITS, FEATURE CIRCUITS or CIRCUIT GROUPS have been activated, then Alexa will respond with “
No circuits are currently running”.
“Alexa, ask MyPool what the Pool temperature is” NOTE: I found that this request will only provide the actual pool temp when the pool circuit is activated.
“Alexa, ask MyPool what the Spa temperature is” NOTE: I found that this request will only provide the actual spa temp when the spa circuit is activated.
“Alexa, ask/tell MyPool to turn On/Off the Pool” (This command will activate the Pool Circuit and turn off the Spa Circuit (if it is on). It will also rotate the “
INTAKE” and “
RETURN” valve actuators to their “Home” (Pool) position), if they are in the 2nd (Spa) position).
“Alexa, ask/tell MyPool to turn On/Off the Spa” (This command will activate the Spa Circuit and turn off the Spa Circuit (if it is on). It will also rotate the “
INTAKE” and “
RETURN” valve actuators to their “2nd programmed” (Spa) position), if they are in the “Home” (Pool) position). Or if your command is
OFF, then it will rotate them back to the Pool (Home) position.
Pool Light”
Heater”
Jet Pump” (This command is for my Spa Jet Pump).
Sanitation” (This command is for the AUX-CIRCUIT relay that I use to energize the IntelliChlor and the IntellipH).
“Alexa, ask/tell MyPool to turn On/Off [Speed 1000] or [Speed 1600] or [Speed 2500]” (These are my configured IntelliFlo Pump
Speed settings).
“Alexa, ask/tell MyPool to turn On/Off [Pump 20] or [Pump 50] or [Pump 80]” (These are my configured IntelliFlo Pump
Flow settings).
“Alexa, ask/tell MyPool to turn ON
Sprays” This command rotates the Pool Return Jets/Water Feature Valve to the configured
Water Feature setting.
“Alexa, ask/tell MyPool to turn OFF
Pool Return Jets setting.
Skim Only” This command rotates the Skimmer/Pool Cleaner Valve to the configured
Skim Only setting.
Skim Only” This command rotates the Skimmer/Pool Cleaner Valve to the configured Pool Cleaner 80%-Pool Skimmer 20% setting.
Heat By” This command rotates the Heater Bypass Valve allowing water flow to pass through the Spa Heater.
Heat By” This command rotates the Heater Bypass Valve, causing the water flow to bypass the Spa Heater.
Filter By” This command rotates the Filter Bypass Valve diverting all water flow directly from the pump to the Pool or Spa directly (as applicable) and bypasses the Filter, Heater, IntellipH Injection Port and the IntelliChlor.
Filter By” This command rotates the Filter Bypass Valve allowing all water to flow through the Filter, Heater (if applicable), IntellipH Injection Port and the IntelliChlor before returning back to the Pool/Spa.
NOTE 1: If you only have an IntelliChem, the following is applicable.
Alexa, ask MyPool what the pH level is
Alexa, ask MyPool what the ORP level is
The above requests, depending on your installed equipment, will return for those with the IntelliChem pH/ORP system only (as checked in the IntelliCenter configuration):
Your <alias> pool is currently 87 degrees, pH is 7.35 and ORP is 725. The pool, chlorinator, etc., circuits are currently running.
For those with IntelliChem and IntelliChlor (as checked in the IntelliCenter configuration):
Your <alias> pool is currently 87 degrees, pH is 7.35 and ORP is 725. Your salt level is 3200 ppm. The pool, chlorinator, etc., circuits are currently running.
NOTE 2: If you ever have to reset your IntelliCenter Control Panel, you will have to go into the Amazon Alexa App and Skills & Games >Your Skills > Click on the Pentair IntelliCenter App on your "smart device and click “Disable Skill” > Disable. Then you will need to “Enable” the skill which re-links your account after you input your Username and Password {sigh}. If you don't do this and try to use Alexa to access IntelliCenter, the response from Alexa will be "
SOMETHING BAD HAS HAPPENED"
However a somewhat easier way to perform this task is to go to Amazon on your desktop. Type in Intellicenter in the Amazon search bar. Click on the “Pentair IntelliCenter” link. Then click on the “Disable Skill” button and confirm “Disable Skill”. Then click on the “Enable” button, confirm that you authorize IntelliCenter Alexa Skill to access your devices?, by clicking the “YES” button. Then enter your email address and your IntelliCenter password to re-link your account, another {sigh}..
Below are screenshots of my current
AUX-CIRCUITS and
FEATURE CIRCUITS that I had to revise in order to make them "Alexa-Friendly". I also included my
CIRCUIT GROUPS just for kicks but remember that Alexa does
NOT currently support
CIRCUIT GROUPS.
That’s about all the info that I have regarding the IntelliCenter Alexa Skill that I have been able to discover at this time. If Pentair releases an OTA that changes any of this or Amazon changes or improves their app, I will try to report on those at that time.
