Not pool in signature
A new to me client as of the weekend. Pool is approx 25k Gunnite, auto cover, 2 skimmers and main drain all separately piped to pad, one return line assuming to two or three returns. Equipment: Easytouch, Intelliflo (011056) 3hp vsp, High rate sand filter, Aquacal HP, Pentair inline chlorinator and a useless Pentair Bioshield UV system. Client is willing to go SWCG so I think IC60 should mix well here. Question: As per enclosed pictures this ET panel doesn't seem to be SWCG ready so I'd need the kit with the power center wired through the ET panel. Also can I temporarily leave the UV system inline and just pull the power so it won't work? And would I just cut at the tees when the clock affords me the time to remove the UV garbage. Thanks in advance, Allan.
