Hi all.. New as of today.. IC40 problem.. I have checked transformer and I am getting 59 vac at the IC40 cable, not the 39 vac I am told it should be.. Could this be a transformer that is putting out too much volts or is there a possible issue with the pc board? I get the 59 vac at the red wire .. Any help is greatly appreciated and thanks for looking
My IC40 no longer has lights.. I have checked cable, breaker, etc.. The transformer is putting out 59 VAC to the IC40 cable.. I am told it should be only 39 VAC but I have checked with 2 meters and both at or near 59 VAC.. Is this a problem with the transformer or do some models have this higher voltage? Do not want to pop the $500 for the unit if it is transformer or the pc board.. Anyt ideas or suggestions muchly appreciated.. Jdoug
JDoug
JDoug
