My son has a Pentair sun touch controller, IC40 SWG, manufacture date 8/09/22 with external power supply. The cell is producing chlorine and functioning normally with all lights steady green. The external power supply has a green light on the circuit board. The problem is the sun touch controller is not seeing any salt. In the swg menu #13 it shows swg enabled, pool 40%, spa 0%, then jumps to the super chlorinate screen bypassing the salt screen. Continue scrolling to the last display and it says salt 0 ppm (com link error). He uses k-1766 and it shows 3600 ppm and the k-2006 which shows chlorine is/has been good, 5-6 ppm. Probably not a big deal since everything else is working correctly but it just bugs me when something isn’t working. Is there a particular component that you could point me towards that might be the culprit?
