Hey all I just opened pool for this season in Northern NJ area. Temp reading on my Pentair Automation is showing outside temp of 52F and Water temp of about 56F
I noticed after about 20mins of turning on all equipment, that the SWG IC20 cell light went from solid to flashing green. I recall from last season, right before closing that this started happening as well and in the automation panel under diagnostics it displays Clean Cell!!!
I have done this and the cell plates are perfectly clean with no residue whatsoever. Before i go out and purchase a brand new IC20 SWG cell, I wanted to ask some advice from any of you that may have some more advance tips I can try to revive this unit
Firstly, is the water too cold to further isolate the problem? and are there any other things I can try before replacement? ie replace flow sensor, or cut some of the wiring that may be falsely reporting temps or salt readings?
Here are some additional details:
-Cell is approx 5 years old BUT advanced diagnostic shows Cell Life 4000 hours (40% LED 2 green lights)
-Pool is only about 8,000 Gals so this cell rarely gets pushed hard
-I have maintained almost perfect water chemistry thru these 5 years
-I have already acid washed the cell a few times last season to ensure blades are free of corrosion
-Salt in Pool is more than adequate
