I have been having an issue for the last year with my IC unit where it just loses power randomly. I have the IntelliCenter with built in power supply for salt cell, and the 4-pin power connector J7, I suspect had a loose pin, that caused it to overheat and scorch the connector, and now is even more loose. If I clean and re-seat it, it may stay on for a few days, but then shuts off again. Anyone else ever have this happen? I see other threads about scorched IC power cables/connectors, but none at the daughter card like this.
The most frustrating part is that in my top of the line (90's technology) IntelliCenter, there is no way for it to alert me or even put a message on the MobileTouch screen that the IC lost power... so a few days will go by without it running and my chlorine gets low, etc.
My two questions are:
1) Am I missing something where I can get some message or alert when the salt cell loses power? Or is my only way to find out by going to look at the cell every day or going to the menu, set-up, equipment, IC screen to see that comm is lost?
2) Does anyone know the connector part # for me to replace the pins/connector on the cable side to see if that helps?
Thanks!
Thanks!
