Hello, long time without writing here… It seems that it is a good indicator and how good the TFP method is as I had not any algae/chemistry problem using it in the last 2 years.
I want to check the usage hours in my IC-40, as I can see in the manual it is done pressing MORE button for three (3) seconds until the lights scroll across the unit.
In my case the MORE button does not do anything, I have checked also in the Diagnostics-Intellichlor screen on the Easytouch and I only can see the measured Salt concentration.
I am not having any problem with the SWG and according to my calculations it should still be at around 50% lifetime but I wanted to check it (purchased 2.5 years ago, 13.5 hours pump time at 30%-40%).
Thank you!
Thank you!
