- Jun 22, 2018
- 83
- Vinyl
- Pentair Intellichlor IC-40
My IC-40 SWCG is just under one year old. Last fall when I put it away it was working perfectly. When I was getting it ready for this year I cleaned it with diluted muriatic acid per the mfg manual. A little scale build up but not much, and I dumped the solution as soon as the scale was gone. It has read "low salt" since I plugged it back up a few weeks ago. My initial salt reading was 2800 ppm. I've added salt to the point where I don't want to add anymore and the unit is still claiming "low salt". All other lights are green. Last run of chemistry (two days ago) is below:
FC - 5
CC - 0
pH - 7.5
TA - 70
CYA - 70
CH - 150
Salt - 3800
Temp - 66 F
I've kept adding bleach to keep the chlorine level up while I figure this out. Before I contact Pentair, I'm not sure what to do other than maybe clean it again with acid? I took a look at it the other day and it appeared to be clean, so not sure if that is the answer or not. The unit is supposed to operate between 2600 and 4500 ppm, with 3600 optimal. Any ideas? Maybe it just needs a higher level of salt to operate?
FC - 5
CC - 0
pH - 7.5
TA - 70
CYA - 70
CH - 150
Salt - 3800
Temp - 66 F
