Looking for help my diagnosing my Pentair MasterTemp heater.
We have a spa/pool combo with the Pentair 4 button spa side controller. All has been working for 10 years. But when the button is pressed at the spa which changes the valves to spa circulate, pump on, heater on, is pressed...the valves rotate, pump turns on but there is nothing responding wit the heater. Normally the heater display would turn on, go through its startup and ignition. But in this case its like the signal is not being sent to the heater to start.
I was thinking it may be the control board on the heater, but get this, I can turn the Pentair EasyTouch Control to Service mode, change the valves to Spa, start the pool pump manually, and then start the heater and the heater starts up and works perfectly.
There are no photos to show other than a heater display that is blank for anyone wanting to see a photo.
Any suggestions as to what may be causing this problem, or suggested method of diagnosing?
29K gal, IG PebbleSheen plaster with raised spa, Pentair IntelliFlo VS Pump, MasterTemp 400 Heater for Spa,
Pentair Tagelus sand filter, Pentair Intellchlor 40 SWG
