- Aug 2, 2023
- 6
- Plaster
- Pentair Intellichlor IC-60
We have a Pentair EasyTouch 8 control system for our in-ground pool and exactly as another post back in 2016 had happen... this past weekend, following a fairly severe electrical storm, the Intellichlor salt generator was not working. When I investigated I found that the problem was that the low voltage circuit breaker that is labeled "Relays" was open. I was able to close the circuit breaker but it would click back open almost instantly. All the low voltage connections (waterfall valve, pool lights, path lights, and salt chlorine generator module) are all inop without that little 3amp relay. I've searched the forums, no luck other than the PCB board guy back in 2016 and I'm not sure that I have the same EasyTouch box made in late 2019 since Pentair changes things every three or four years. I'm a broadcast engineer so I checked the voltage going to the Intellichlor transformer (yellow and white wires) and it appears that the transformer is getting no voltage at all. Any thoughts/suggestions would be appreciated. Need the pool operating again asap!
