- Jul 31, 2021
- 299
- Plaster
- Pentair Intellichlor IC-40
I am investigating the possibility of getting a heat pump for my pool. Natural gas is not available and propane is crazy expensive for me. Since I have a small pool I think a heat pump will work great. Anyways I was looking at the easy touch to see how you can control the heat pump. I was a little disappointed that it doesn't look like you can have much control on when and if the heater turns on other than a single temp set point. What I would like to do is have an automated bypass that turns on as well as being able to run the heat pump only during the daytime hours. Since I don't have a spa but I have the spa function on my controller. I thought I could use the spa function and set that to my pool temp and wire my pool thermistor into the spa header. If I understand it right I can then set spa to run from say 10:00 a.m. to 6:00 p.m. during the warmest part of the summer days to heat the pool and not run during the cooler nights. This would also activate the automatic valve bypass that I plan to install.
Just looking to see if this seems feasible?
