Hi, I currently have a very old 2HP pump, connected into my Easy Touch panel. The 2HP is dedicated to a fountain going into the pool. At the full 2HP, the water flow is very heavy and I'd like to be able to change how much water is getting pushed into the fountain. My thought was to get a new Intelliflo VSF pump, then use the ScreenLogic app on the phone to select the desired pump speed... some days would like 3k RPM, others perhaps 1k RPM. Is that possible to do in the ScreenLogic app from the phone? Or perhaps there is a roundabout way to program it, e.g., use 2 circuits and have a designated speed assigned to each?
Note that I do have 3 available circuits on my EasyTouch. I also thought about the SuperFlo pump, which had 3 speed settings, but not sure 1.5HP would be enough for when I want it running at full capacity (e.g., current 2HP pump).
