- Jul 22, 2023
- 266
- Plaster
- Pentair Intellichlor IC-60
Well, my PB is covering the cost. Since they don't know what their own crew hundreds of miles away from them installed, they are asking for photo and part number.It is often less expensive to buy a complete new diverter and use it as a parts donor then buy the parts individually.
The diverter for those valve is 270075, for the 1.5" - 2" Pentair valve. The valve with the actuator on the horizontal pipe uses a 270056 diverter, 2"-2.5" valve.Well, my PB is covering the cost. Since they don't know what their own crew hundreds of miles away from them installed, they are asking for photo and part number.
The issue I'm having is since the valve isn't closing fully, the pool looses water from the three laminars up to the height the water trickles out of the laminar into the laminar bucket down the drain hole to the yard.
With all the leak companies that came, they say they cannot pressurize due to the valves not closing fully but after many months, this appears to be the only place the pool can be leaking water.
Vertical installation of valves is very difficult to do without getting glue dripped into the valve.If this has been the situation since the pad was new, a possibility is that whoever did the plumbing slopped some PVC glue on the valve seat.
This is false. He's either misinformed or fibbing out of self-interest. Jandy/Pentair/Hayward valves will seal 100%. And do this for years and years and years before service is ever needed.It's funny, the plumber said quite the opposite, he said all valves always leak and that it is hard to ever get them to seal.
No. Not unless you go at them with a knife. The components are tougher than you'd think.One question, if I open them up, wouldn't I need a rebuild kit still or o-rings to put them back together again?
As mentioned, the PB and several leak companies have come in. Unless they haven't done that or don't know how to correctly, I would say they have all tried using service mode to position the LEDs for full stop.@tradewinds You have intellivalves.
These are unlike the "old" style and you are relying on the LED column to tell you the position of your diverter.
Have you, or anyone else, removed those and used the original diverter handles to ensure the rotation is full-stop and then watch for the leak behavior you've described?
If not, and were I a betting man, I'd wager a blushing sum those are not provisioned to close the valve fully.
If he's a crummy plumber, the new valves frequently not working is his truth.This is false. He's either misinformed or fibbing out of self-interest. Jandy/Pentair/Hayward valves will seal 100%. And do this for years and years and years before service is ever needed
That leak into the IntelliValve actuator is a common failiure mode of the IntelliValves. A tear down of the unit finds the two case half’s lack any seal or gasket to keep water from entering the actuator internals.In fact, the actuator at the top had water in it and had to be warranty replaced. No one can say how water could have got in. Not PB or Pinch a Penny who got the warranty work order from Pentair. The diverter valve was tested by them and didn't show any signs that it would have leaked and drove pressurized water into the actuator. .
