This is a newbie question. My SWG manual (version 3, units after Nov 2011) says
Monthly Service (Continued)
3.Cyanuric Acid:Sample the pool water and test for cyanuric acid level using a reliable test method.When using the IntelliChlor SCG the recommended ideal cyanuric acid level is 30-50 ppm.
Older version of the same manual recommends 60-80 ppm.
I understand from my initial reading here and elsewhere that cyanuric acid level influences level of free (and active) chlorine. Tested with Pentair Rainbow my cyanurate is about 40, and my chlorine is between 2-3. I noticed that with warmer weather and leaving my solar cover off, Cl level dropped a bit and I increased generator from 30% to 40%. Water is clear, so no immediate problem here, but I'm a bit confused as a very thoughtful article recommends lower range cyanuric acid (New Thinking: Chlorine/Cyanuric Acid In Balance - AQUA Magazine), as does mfg, c/w TFP pool school and many other sources, including mfg prior to 2011. Aqua mag article (and associated comments/discussion) makes point that increased cyanurate requires much higher total chlorine level to get equivalent disinfectant activity. However, lower cyanurate may require more Cl production by the SWG due to UV especially now with summer on the way.
What is the best path for me, should I increase cyanurate?
3rdcoaster
3rdcoaster
