My LX100 dates from 2001 and the manual wasn't supplied when I purchased the house. I've added solar panels for heating and am about ready to add a solar control system and a chlorine generator. Have a variable speed pump which bypasses the LX100 timer as the pump has it's own timer.
Is it feasible to:
- wire the chlorine generator power to the LX100 pump relay and use the LX100 timer to set the power on/off times. The chlorine generator has a flow switch in the cell.
- wire the solar control system to receive power from the LX100. The solar control system "talks" to the pump so I suppose the power needs to be constant. Which LX100 relay, if any, would be good for this?
Thanks for the assist.
Jim Harnes
Is it feasible to:
Jim Harnes
