Pentair Compool LX100 Connections
jharnesjr
2
Sarasota, FL
My LX100 dates from 2001 and the manual wasn't supplied when I purchased the house. I've added solar panels for heating and am about ready to add a solar control system and a chlorine generator. Have a variable speed pump which bypasses the LX100 timer as the pump has it's own timer.
Is it feasible to:
- wire the chlorine generator power to the LX100 pump relay and use the LX100 timer to set the power on/off times. The chlorine generator has a flow switch in the cell.
- wire the solar control system to receive power from the LX100. The solar control system "talks" to the pump so I suppose the power needs to be constant. Which LX100 relay, if any, would be good for this?
Thanks for the assist.
Jim Harnes
Jim, welcome to TFP.
Is it feasible to:
As long as the time schedule your LX100 is inside the times the pool pump is on this would work.
The cell flow switch should be a secondary safety device. The primary safety device should be a timer insuring the cell is not powered when the pump is off.
What pump do you have? What cell do you have? Please create your signature with details of your pool. It helps us give you more specific advice.
