Matt, again, you seriously rock. Tx for your help. Got this done and in about 5+ min. Easy, breezy! ~$15 is much better than the ~$130 for a new CVA-24T. Don't want to jinx anything, but is working like a charm. I tried to take step by step pictures so it can serve as a reference for others. This time, I left the unit on the diverter and just simply removed the top portion. Additionally, I only switched off the toggle switch to OFF but did not use my needle nose pliers to unplug the cord plug-in on the internal circuit board on the lower left area.
Flipped to middle position - OFF.
Untitled by
B Brockman, on Flickr
Tools on hand
Untitled by
Remove screw cap holding down handle
Untitled by
Cap off. Now remove 4 screws securing top.
Untitled by
Untitled by
Remove top
Untitled by
Untitled by
These are the 2 switches that will be replaced
Untitled by
The replacement parts
Untitled by
Gently remove the 2 electrical lead wires feeding the switch, and note their position. Remove the little screw securing the switch, make note of the switches orientation, remove the switch, and replace it with a new switch, and fasten it down with the little screw that was removed. Then, reconnect the lead wires. Replace the opposing switch as noted.
Untitled by
Untitled by
Untitled by
Then, replace cover ensuring that the lead wires are tucked in vs. under the cover. Replace the top cover. Fasten down with the 4 screws. Replace handle and fasten down with screw cap. Flip the toggle switch to the correct position for your solar system. And, viola, system operational.
by
by
