Pentair acid feeder
mattcgtx
2
Arizona
Was thinking about putting acid feeder on my pool the instructions as far as the control portion seem a little vague to me. It all references hooking in with the salt water generator. I don’t have one of those. In addition, I have the easy control center so is the controller standalone or does it interface or integrate with the control center? I know these are newbie questions but my pool guy is not really interested in helping me out with this at this point.
How do you chlorinate your pool?
Look into a Stenner pump.
That’s a bummer
I don’t have a SW pool??
Are any other brands that might have a feeder that is stand alone??
TIA
A salt water chlorine generator is far more useful than an IntelliPH, especially here in AZ. Pool care becomes boring and you can save the money you pay on a service tech that, apparently, doesn’t want to help you anyways …
Follow all of the ways we recommend to maintain your clear and sanitary water and then invest in the SWG that will save you a few thousand in chlorine. Then all you would need to do is monitor the FC and occasionally add acid. If the pool is new or recently acid washed or replastered then it will use more than average acid for a year or two. Follow the CYA/FC relationship religiously and you'll be fine.
Pool Care Basics
Test Kits Compared
FC/CYA Levels
PoolMath
