We have had our new pool filled up for 22 days. We are still under the maintenance of our PB as we are in the “startup phase”. They have already added salt to our pool (which I fear is too high) but we are not able to use the SWCG due to a faulty sensor. They have contacted warranty to fix the SWCG - not sure with the pool temp in low 50’s it will even work in the first place. So right now our PB has been coming out to test and add appropriate MA and liquid chlorine. We had clearance to use the pool/spa as the levels were being monitored and we had no more dust when brushing the pool. We decided to use the spa over the holiday and didn’t have any irritation issues (maybe due to the CYA level and salt in the pool) but we now learned we should have checked the levels ourselves before entering. Checked levels tonight to play with my new TF-100 kit and couldn’t believe how high our FC levels were (FC: 23 and CC: 0.5) Why would they have added that much chlorine? Our SWCG hasn’t been on that we know of so assuming it was manually added in excess. I checked the CYA/Chlorine chart and saw it was still okay for us to use the spa bc we were lower than shock levels but still. Will the FC go down on its own and how long will that take? Can it hurt our new PebbleSheen being that high? Also our salt is above 4000. Is that a problem? Strip said 4,000 so I used the Taylor K-1766 NaCl testing kit to get a more specific reading (4,200 ppm).
