Added a couple pictures so everyone can see the progress.
Here is everything plumbed up to the VSF pump currently: (all of this is plumbed to go through the C&C 320 filter, IC40 and ultratemp (although ultratemp has a bypass)
1) Slide-2" line (125-150 gpm requirement)
2) Pentair Magic Falls -2" line to feed 2-12" arc sheets (~10gpm each) on the small columns that will be on the sides on the tanning ledge
3) Pool return-1.5" line 3- 1.5" return jets (? gpm)
4) Tanning ledge-1.5" line 2- return jets (? gpm)
5) Tanning ledge bubbler- 1.5" line (? gpm)
I did some flow testing today and it seems like the VSF can outrun the skimmer. With only the pool and tanning jet (3 & 4) valves open, the pump seemed to almost empty the skimmer at 75 gpm. (The water level was within 1.5" from the top of the skimmer opening)
This makes sense since the skimmer is a Waterway Renegade that advertises a 75 gpm flow rate:
Here are the waterslide specs:
Here is how I'd like to revise the pump/plumbing:
VSF pump: (through C&C 320 filter, IC40 and Ultratemp)
1)pool return jets
2)tanning ledge return jets
3) tanning ledge bubbler
Intelliflo XF pump with 3" suction line (no filter, no heater)
1)Slide-3" line
2)Pentair Magic Falls- 2" line to feed 2-12" arc sheets
How does this revision look?
What wall ports are available for a fiberglass pool that will feed the XF enough water?
What's the best way to improve the VSF's suction flow? Another identical skimmer?
The PB said there's an additional unused port on the current skimmer that he can tap into, but I don't see how it could exceed the published flow rating of 75 gpm.
Thanks again for any assistance!
