Hi everyone,
We are in the middle of installing a fiberglass pool and have most of the plumbing connected, but have not poured the concrete deck yet. I'm playing around with the pump speeds and noticed that I can't flow much more than 75 gpm. This is our first pool, so I'm still learning how these systems work. However, I started researching and noticed the skimmer we have is rated at 75 gpm, and 2" pipe maxes at around 75 gpm as well.
My PB is convinced the 011056 VSF is maxed out at 75 gpm. He said no matter how many skimmers or the size/number of suction pipes that I have, the flow is restricted due to the 2" inlet port and therefore the flow is ultimately limited by that size. Needless to say, he is not one to calculate head or reference pump curves. (insert face palm emoji here)
I attached a picture of the exact pool, tanning ledge and water feature setup we are copying for reference. I knew it would take a lot of water to support these features so I was trying to get equipment that could keep up.
I'm fairly certain the only way we could achieve anywhere close to 120 gpm (the filter flow rating) is with a second skimmer and parallel 2" suction lines that merge to 2.5" near the pump.
Here is what we have:
Intelliflo VSF 011056
Pentair Clean and Clear 320
Pentair Ultratemp 140
IC40
Intellicenter
Any advice would be greatly appreciated. This build is definitely pushing the PB out of his comfort zone of plain vanilla pools and 30 year old equipment.
IC40
Intellicenter
