We are building a new pool in SW Florida and are trying to decide what is better, Concrete or pavers? Any and all suggestions are greatly appreciated.
I have stamped concrete. If I had to do it all over again, PAVERS all the way. The soil was prepared properly, crushed stone, drainage, etc. Still 5 years later, hair line cracks, really only noticeable where the cups are for the ladder and hand rail by the stairs. Other areas have not been compromised. Pavers will cost, IMO, about twice as much as concrete.
Why do you hate stamped? The expensive & laborious maintenance products to keep it looking fresh? Too hot on your feet?
i think pavers are better for the reason that if u have an issue u can rip them up and fix issue and put them back down and never know there was an issue. concrete won't match exact if u have to redo areas. pavers yes more expensive especially if they are installed correct with a 4 inch pour under them. but again that will prevent heaving and such in my climate. my driveway is concrete. it was installed perfectly but still have cracks like mentioned above. i should have not listened to my fathers friends cause they were trying to save me money and did pavers over concrete and called it a day. i could have gotten 2 inch bluestone for pennies from a farmer my uncle knows it would have been beautiful but they wanted me to do concrete.
i would say after having pavers now for over a year. pavers all the way. my neighbor had to redo his lines for his pool. he has pavers. my buddy ripped them up. they fixed everything. put pavers back down. never knew anything was done.
jim
A concrete base is NOT the correct way to install pavers.
My pavers have a small amount of concrete on the outer edge and then the inside is filled with a very fine sand. Almost like dust. Then it was compacted and the pavers laid. After all that a sand was grouted in with the pavers. Then finally they watered. Once this was done it formed a concrete type bond with all the pavers.how do u figure. 1. it gives the proper base to properly attach a safety cover. 2. it prevents heaving in the weather. i can show someone a ton of jobs that were done with concrete under them and they are all prefect and some are old installs. yes i can also show the same without concrete, but most are not as good as concrete ones than those without. the only way you will get heaving with pavers on top of concrete is if the concrete below totally fails.
U can do them both ways u must use stabilization fabric over concrete if u do. If u use geo fabric under 6" of compacted DGA and the base is compacted and prepped right the pavers won't move.
