Patch vinyl liner
youngguon
Active member
Sep 12, 2019
38
OH
Need suggestion to patch a rip on vinyl liner. It's about 3 in on the wall above the first step. It's concrete inside. It's awkward as I cannot press the patch against the wall as it'll rip more. Good thing is I can lower water level to keep it dry. Any suggestion about how to fix it with what product or tool would be appreciated.
Pool_Medic
In The Industry
Apr 1, 2018
1,197
Bangor Maine
That looks very brittle? If so it’s past it’s last legs.
If not brittle, you can patch it but it will require several overlapping patches. Just be patient.
youngguon
Active member
Sep 12, 2019
38
OH
Brittle but not sure if it's very. I'm selling the house so will give patching a try definitely. Any patch you recommend?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
33,425
That's a huge rip for a patch! Please let us know if it works. It may be tough to get it to hold water.
JamesW
18,601
That liner is done. It's time to replace it.
Are you going to tell the buyer or let them figure it out on their own?
youngguon
Active member
Sep 12, 2019
38
OH
Ok, in any case, it's done. All it will take to pop the liner is a poke anywhere and the liner will split open and the pool will drain.
I brushed, vacuumed, raked the pool on daily basis in the last 2 months. Only poked a hole basically above the water level and it didn't split in the 3 days before I taped it...
JamesW
18,601
It's like when your tires are completely bald and someone says that they're fine because they drive on them all the time.
It's just a matter of time before there's a catastrophic failure.
