Have a super old and unsafe pool timer. Has a neutral terminal, line terminal and load terminal.
There is a 2 pole 30amp breaker feeding a 40amp 2 pole desperate contactor.
The load side of contactor is connected to the pump.
There is a 120v 15amp feeding the timers neutral and line.
I also have an IC40 installed and they have the hot on the power source terminal of the timer so of course it’s always on.
Anyways I want to replace the timer. Since I really have 2 loads that are 120v what intermatic outdoor timer would work? Anyone using anything that is controlled with an app?
