Pad set up.
theewings5
21
Westerville, OH
Pentair Intellichlor IC-40
About a week or two away from pad set up. If you can see picture let me know if this is a good set up. Or if it needs changed. But I do have a couple of questions. 1. Do I need a by pass between filter and heater? And 2. I think I bought some magic beans, should I install the 2 CMP compact pool defender anode and water bond? If so where should they go?
FYI
Pump Pentair 011056
Filter Pentair C&C P 520
Heater Raypak 406
Thanks for looking and any help
You do want to be able to bypass the heater.
I don't see any shut offs. You want to be able to isolate each suction source and each return. That way if something breaks, you don't automatically have to shut down the whole system, you can (for example) plug the leaking return line and keep the pump running.
Pool anodes are magic beans. Water bonding is essential for safety.
