That is key. This thread started with you being extremely discouraged and unsure of yourself. While this may seem like a setback, you are now sure of the testing processes, using your test kit, and completed a SLAM. Your water does look fantastic, but now we need to figure out why the FC drops. It's not rocket science and we'll figure it out.
So let's just start again. Once step at a time, beginning with a new
Overnight Chlorine Loss Test if you are up to it. I suspect it's getting dark there, so if you are able, increase the FC anywhere around 8-10 ppm if you can. If you can only go to 5 or so, that will work, but something in that area. Confirm one final FC test before bed and test again in the morning. Let's see if we're dealing with algae again or a CYA problem. I doubt you have any questions about the FC test, but just to be safe here it is again.
10ML water sample with ONE generous/heaping scoop of powder. Mix and add drops until clear. Take that number and divide in half. Example - 20 drops equals an FC of 10.
Let me know how it goes.
