Oona
My PB mentioned when they dug his pool that this how they had to excavate the hole- with walls that slope out. He said that they do this with loose dirt/soil so it doesn’t collapse down into the hole
I guess I could see that. There’s also plenty of builds that have plywood forming the walls where the dirt collapsed or was over dug. My excavator made it sound like it was a structural issue.
Hopefully in my case the ground will stay cold enough not to cave in until I can get the gunite!
I’ve never heard of that before, but since I’m doing it myself I guess I’m out of luck on that. At least right now I’m not too concerned about any cave-ins. The dirt seems pretty solid. A bunch of snow/rain could change that though.If a dig will not get gunite for a while a good builder will flash the hole with a thin layer of gunite to provide stability until the full application can be done.
Have you considered a large cartridge (CCP520) filter?Filter: Pentair Quad DE 100
I thought about it, and went back and forth honestly. The CCP520 is about the same price, and that and the Quad DE 100 are very similar filters. Ultimately I decided for the same price I wanted to get a little benefit of having DE (if there is any) without going to a full blown DE filter.Have you considered a large cartridge (CCP520) filter?
Good stuff here, I am planning on most of that. I like the idea for a light. I'd see others recommend that, but hadn't added it to my list.Other things to consider:
-Make sure everything at the pad is connected with unions.
-It's recommended to have a segment of straight pipe before the SWG, so plan for that.
-Consider an autofill and overflow drain.
-Install a light over your equipment pad.
-Consider a surge protector at the load center.
-Think about adding GFCIs, running landscape lighting wires, and extra conduit for future options.
-Are you getting a robot? Think about where that will plug in and if you'll be able to conceal the cord.
-Install the anchors for a removable handrail
-Umbrella sleeves?
I'll be using Intellicenter. How do I add a surge protector to that?
My equipment will be about 3 feet higher than the pool. Anything I need to do specifically for that?
The convenience of a large cartridge filter can't be beat. It filters extremely well, and your water will be crystal clear. Plus, no DE to mess with.Ultimately I decided for the same price I wanted to get a little benefit of having DE (if there is any) without going to a full blown DE filter.
The bell end is so you don’t need to use a coupling. It is deeper than a coupling so it makes for a stronger fit. You buy less couplings this way.Not a lot of updates. Dug out a little trench for the bubblers, and some other prep work for plumbing. Got all the plumbing supplies I need and the rebar delivered. I’ve got the rebar guys scheduled for the 21st, so I’ve got a week to finish plumbing before they get there.
The only pipes that were In stock we’re bell end pipes. Does it matter if you use bell end or plain end pipe? Is one ‘better’ than another?
Our build is in progress but pool coping is done and is 3&1/2 by 22 wide, I have some photo's posted.Got a call earlier today from the paver company. Turns out the coping we were going to use doesn't come in 60mm (2-3/8"), only 90mm (~3-1/2"). The deck pavers are 2-3/8". I'm not too worried about the deck, I think I can just bring the other pavers up an inch to match the level of the coping easily enough. I am worried that the extra inch will look too big. That really seems like pretty thick coping.
That also bumps up the water level to the deck to about 7-1/2" or so, instead of 6-1/2". I guess I could always raise the water an inch or so, but probably not more than that. Am I worrying about nothing? Does anyone have coping that thick with pictures?
