- Feb 6, 2015
- 7,809
- Plaster
- CircuPool RJ-45 Plus
Our water here in Gilbert is super hard. We finished our pool last Feb. By fall the CH numbers were approaching the highest acceptable. We had to drain it to have some plaster smoothed out so we started over. I really don't want to drain it every year. I'm wondering how expensive it would be to add since we already have a whole house softener. Hopefully cheaper because $3000 is not in the budget.
Is the softener in the garage?
Can you run a soft water line thru the garage outer wall, down into the ground and to near where the autofill piping is?
If so, it can be done pretty easily.
Below is pretty much what I did - note, I don't have to be concerned about freezing temps where I live.
- Use copper pipe for all above ground piping in the garage and near the garge exit point
- Tap into the soft water line in the garage using a coppe tee
- Place a brass shut off valve (brass ball valve) in the line after the connection to soft water
- Run copper pipe thru a hole drilled in the garage wall at least 18" above grade
- On the outside of the garage, place a backflow preventer on the pipe where it comes out of the wall
- Run a copper pipe from the BFP straight down into the ground (at least 4-6 inches underground in the desert southwest, probable deeper elsewhere)
- Underground, convert the copper pipe to PVC (at least sched 40)
- Run PVC pipe all the way to your present autofill line (or dig down and find the lateral pipe nearer the autofill
- Tie into the existing autofill pipe
- Paint all exterior above ground pipe the color of the surface it is located on (copper and PVC)
Of course, check your local codes for requirements.
