No. I set it up so I can disconnect the water softener and cap it if I decide to stop using it. At that point the autofill would work as the pool builder designed it and non-softened water would go to the pool.Hmmm... that's interesting. Do you have that permanently connected to your auto-fill? How often do you have to regen it or do any kind of maintenance?
I added a water flow meter to the line that feeds the water softener so I can measure how much water is going through the softener. I'm not sure yet how long I'll be able to go between regens as I'm not sure how much water will be added to the pool (I'm a new pool owner). I did regens about every 5 weeks or so when using the water softener for our RV while living in it full time. I'll measure the water hardness over the next few weeks and when it needs a regen, I'll document how many gallons of water went through the softener. After that I'll just do the regens based on gallons used rather than measuring CH all the time.
Just to clarify something in the photo below - The black cap for the tee on the left side of the photo is just sitting on that electrical box. I wanted it nearby in case I decide to stop using the water softener. Figured I'd lose it if it wasn't nearby.
It's definitely not pretty but it works:
