It's a good thing they used solid core instead of foam core but every fitting I see is a drain fitting. They are all schedule 40, the difference is that drain fittings are not made to be part of a pressurized pipe system. I just read this thread and it looks like all your drain fittings passed inspection somehow because everything got buried. That should not have passed inspection! They might not leak right away if they used the right glue, but it's going to be an issue down the road.Plumbing connected - getting ready to back-fill with sand and then dirt/stone. Compacting this week and preparing for the big pour.
Looking good! Was it difficult to keep the rafters from tipping before installing the horizontal bracing/spacing poles?
Looks like those fall leaves are starting to turn and you'll probably be trying to keep them out of the pool soon!
