- Apr 7, 2014
- 196
- Intex Krystal Clear
Everything seemed to break at the end of my swim season last Nov. (I’m in Florida but we don’t swim below about 75 since the pool is not heated.) My SWG kept reading low salt even though it was perfect, my filter pump developed a major leak, and my Polaris 65 bit the dust. (and on top of that the hot tub broke -we had to replace the circulation pump). Florida is BRUTAL on everything. My hubby is handy so after trying to fix all of the above last month and realizing the fixes were almost as much as replacing, we ended up just replacing. I ended up using a floater and pucks all winter since we get really warm days and the pool can get warm enough for algae, which we got since I could not run the pump much because of the leak. Set everything up, ran the new sand filter (I had a cartridge filter before) and Polaris all last week. Pool LOOKS beautiful and clear. Check my readings and I am out of whack. I’m not really surprised, but still ☹??
FC 15.5
PH 6.5
TA 40
CYA 90
temp 70f
I just added 3lbs of baking soda (first time ever having to). I’m going to check the TA again tomorrow, then work on the PH. I’m usually the other way around high TA and high PH, so I‘m going to have to get more baking soda and some borax. Should I wait til my FC goes down or keep working on the TA?
I’m going to let the CYA ride for now since we will be having rain overflow pretty soon.
Luckily we wont be swimming til end of March, so I have time to get my pool back to normal. And it could be worse! I could be living up north with a winterized pool, or I could have algae.
FC 15.5
PH 6.5
TA 40
CYA 90
temp 70f
