- Jun 1, 2018
- 16,114
- Vinyl
- Hayward Aqua Rite (T-15)
The chlorine & cya pretty much in tandem.As long as my pH stays down I guess it worked out. Thanks guys. Next time I fill and start again what is the first thing I should do:
Add 30ppm CYA
Add chlorine to shock level
Start acid to lower pH
Can I do all of the above at the same time?
You’re putting the cya in a sock/panty hose right?
Give a couple minutes between chlorine & MA.
Then when ta gets closer to your goal use lower swings for ph (aim for 7.6 instead of 7.2)
After ta is 50/60 then add borates.
Btw- That’s alot of ahhsome- you may be also dealing with some residuals of it .
Just wipe any residue away with a microfiber cloth & rinse your filter.
Keep the fc up to help oxidize anything funky.
Remember-
No kissy face with minimum
