Our pool pumps PSI is too high
Also take a moment to update your signature. The link below will help guide you. That info is extremely important for us to answer your questions. Include which test kit you use as well.
Jen,
High filter pressure is not normally due to the pump being 'too strong', but rather a restriction in the flow of water back to the pool.
In most cases this is due to a dirty filter..
If you have not cleaned, or backwashed, your filter recently, then do it now..
Keep in mind that algae, can clog a filter is a day or less... So if the problem quickly returns, then I would suspect algae..
How are you currently sanitizing your pool water?? Chlorine tablets, Liquid Chlorine, or some other method??
