- Jul 21, 2013
- 65,525
- Plaster
- Pentair Intellichlor IC-60
Is there supposed to be water flowing throw the the pump basket?
Is the pump on?
So what do I do?!?! ?If pump is on then water flows through the pump basket.
I could not see what was going on in the pump basket. Can you describe the problem?
If the pump basket is full of water you will not see the water flowing through.
If the pump is truly running dry you would heat strange noises from the pump. A pump does not last long running dry.
Sounds like you may have more construction debris blocking a pipe.
My gut is saying there is stuff in the pipes and every time you turn the pump on and off the water movement is causing the stuff to move or shift. GURRRRRRRRR on them not getting all of the stuff out of the pipes!
PH is LOW and Alkalinity is LOW.
Need to adjust but it's raining like crazy now and for a few days.
Should I wait? I intend to adjust Alkalinity first and see where pH lands.
I also need to check cyanuric acid.. good thing my test kit just arrived ?
Please provide actual test numbers from your TF-100.
Oh shoot... Ok I understand.Yes, raise your chlorine. Beyond that we can’t say without seeing TF-100 test results.
You need to decide if you want to follow pool store testing and advice or TFP advice. Don’t try and mix the them.
