- Jul 21, 2013
- 65,516
- Plaster
- Pentair Intellichlor IC-60
CC of 0.5 is normal sanitation by chlorine happening. You only should get concerned if CC is 1.0 or above for multiple days.
You are expecting too much from PoolMath. The pH change predictions are complex. The Effects of Adding section does not consider TA while the other section does.
As pH change gets greater then 0.4 PM gets let’s accurate. Do pH changes in small doses and test in between until you get to the desired level.
