Here it is Mike for future reference, I want to make clear we did not jump the gun and use this for algae. We followed the SLAM as close to the letter as possible, numbers steadily proceeded but clear water did not. We felt we were ready to give up until you and a couple others suggested the Alum floc...it is a great last effort before draining but only after all numbers are good. Had to let chlorine go down before the floc to check ph. It recommends to adjust ph to between 7.2 and 7.6 our was 7.5 .. We followed directions on container to mix with water pour into skimmer and circulate for 2 hours..almost immediately it began coagulation and looked like the ice in the Titantic movie..lol..turned everything off after 2 hrs and waited til morning...
The dosage on container was 4 to 12 lbs per 10000 gallons of pool water we went on the lighter side figuring that we could always do again if necessary. We used the 10 pound container..cost is about $38 at Leslie's here... It also says it can be used as a filter aid, not sure how I feel about that but it says it can. Says vacuum to waste and when finished backwash and turn on circulation system. Readjust TA and ph if needed.. Ph is def needed. Dropped ours to 6.8...
Once again great for water that will not clear after passing OCLT and cc .5 or less. This stuff did an amazing job. Alot of work vacuuming but well worth it for us..
This is the product we used..
I can't thank all of you that helped on this project enough. Some of it was hard to wait on especially after passing OCLT but it was worth it.. Hopefully I will get to post pic of that quarter in next couple days, unfortunately for us and pool its supposed to rain here tomorrow and maybe the next couple days. Hope it warms back up so MAYBE we can get a week of swimming with my grandson in before we have to close up..Thank you all...
Mary and Allan
Sent from my XT1254 using Tapatalk
Mary and Allan
