The prevailing wisdom seems to be that a pool's solar temperature sensor should be near but not touching the thermal solar panels. This way, the sensor is getting the same sun as the panels without being affected by the panels.
I now wonder whether this is non-optimal. It seems to me that the sensor should be in contact with the panels, so it can read the temperature of the water inside the panels. Then, as the water in the panels cools due to circulation through the pool, the sensor would correctly read lower and might even disable solar if the water temperature in the panels got low enough.
Comments?
Comments?
