Hello, I have enjoyed owning a hot tub for about two years, and have learned so much from this site and from owning the tub - thank you all!
My current tub has a small leak. I seem to need to add maybe 20gallons of water every 2-4 weeks. The tub is 13 years old, and I do not want to troubleshoot, as the only access to the jet plumbing system is from the bottom of the tub. The leak is not coming from the pumps or anything.
Here is my question. As I look at new tubs, several of them offer an @Ease Inline system as an option. One of the things I learned about myself as a hot tub owner, is that although I checked, tested, and adjusted chemicals every day for awhile, as time went I on and job demands, vacation, and other distractions happen, I became far less reliable and accurate, especially in winter. I am embarrassed to say there are times where I forget about the tub maintenance for 5 days or so, and when I check of course FC is Zero, and pH is high. I also hated to have to add chems after people used the tub, it seemed like a hassle.
I am VERY interested in a system which requires once per week checking and adjusting, versus daily. Based on my research to date, it seems like after getting the initial fill water balanced, then the system takes over, and only requires testing/adjusting TA and pH once per week until the next drain/fill. This is very appealing to me. It seems like the downside everyone points out is the cost, and also the cartridges may not last as long as advertised.
The only thing I don't like, in addition to cost, is I am not really sure what is being added to my spa water. JoyfulNoise had some good insight there.
I have learned here that adding the purest most basic chemical is a preferred method of adjusting chemicals, and I have been doing this to date, however on a hot tub this requires daily testing/adjusting, etc..
I would welcome additional insights and opinions. Thank you!
