Check in the early morning before the sun hits the pool but only after the pump has been moving the water for 15 minutes. That will give you some idea of how it's holding thus keeping the sun out of the equation.
Im new also how often are you testing?Log. 5:30pm heavy rain and thunderstorm all day: 11.5 fc 5.5 ppm drop. Added 2 quarts of bleach.
8:30 pm last test of day:No rain in forecast the rest of the night. 19fc
Usually twice a day. Since I work during the day. One morning one evening. Been officially doing slam since Sunday when I got my taylor test kit. Before that I wasn't really doing it properly.Im new also how often are you testing?
Is your pool a fresh start up?Ok thanks! I’ve started with my kit and just been doing what it suggests
Yes, trying to get it balanced. Inherited it with the houseIs your pool a fresh start up?
Thats great! Have you already read the pool school information? Was the pool already filled? What are the last readings you took?Yes try
Yes I have I’m about to test. I need to drain lots of rain yesterday. I’m way below but poolThats great! Have you already read the pool school information? Was the pool already filled? What are the last readings you took?
Math isn’t telling me to add all at once
then I may need to add moreWhether your performing a SLAM or just maintaning FC levels you should add all the Chlorine at a time to reach the level that its telling you. So for example if CYA is 40 and you are just maintaining at 5 ppm FC and you test and the FC is at 2 ppm you would add 2 cups 5 oz of 10% bleach all at once to bring it back to 5ppm.
There are 2 things that consume chlorine. 1 - Sunlight, 2 - Organics (Algae, Leaves etc.). So you will be fighting a losing battle if you are just trying to gradually increase the FC levels. The most important factors to know are the CYA (Stabilizer) level and FC. CYA is what protects the Chlorine from sunlight etc. But it also makes it less efficient. So we need to make sure we have enough FC based off the CYA level at any given time to kill any forms of Algae and Organics etc. to make the pool water stable If you have no or very low CYA you will burn through the Chlorine levels very fast. On the other side of the coin a High CYA level will require a higher FC target level to reach whether SLAM or Maintain.You can see my logs on my thumb nail
Any FC above the cya ratio will disappear fast so your idea is wasteful. I would recommend you use pucks for thar duration to continuously feed chlorine. Whe you get home get'em out of there.I'm going to be out of town Saturday and until Late sunday. I have been performing SLAM. I do not have anyone to test and add bleach to pool. Should I dose to really high FC on friday evening to possibly hold out until Late Sunday?
Ok, sounds like a plan thanks. Im thinking hth calcium chloride pucks because I don't want add any stabilizer?Any FC above the cya ratio will disappear fast so your idea is wasteful. I would recommend you use pucks for thar duration to continuously feed chlorine. Whe you get home get'em out of there.
