Opening pool myself for first time so I'm looking for help getting things going. I've got everything thing reconnected and running as of now. The issues now are the water is pretty cloudy (could barely see the bottom of deep end) and the clorine generator has the no flow lit solid. I'm not getting a salt level reading on it either.
Once I got filter running I brushed the pool then put in some shock. Had my filter going for about 3 hours and noticed hardly anything coming out of return jets. Filter PSI is now about 10psi higher than when I started. Is this expected with a DE filter or did I forget something?
What do you recommend the next steps I should take to get the pool clear and get the clorine generator running
