Almost did. Had sort of a panic attack. But we made it thruLooks great Monte!
And yeah, I thought we scared you off for good somewhere around page 3-5.
Thank u very much. U r very kindPool looks great you should be proud! You have learned a lot since what I read at the start of this post. Also that is beautiful fence!
Above grounds don't allow adding chlorine once covered, when properly secured. You'd never get in a AB pool I covered either.And when he puts the cover on plus the leaf cover it has very little give to pick it up and add more bleach if that is what is needed especially since there would be no way to mix the bleach??
It's not so much next week as it is last week. The water is warm and will take 5 days or so of cooler weather to drop. IIRC you can average 5 or 7 days highs/lows and get a pretty good guess on the water temp. The pool water fluctuates too so depending on the time of day you test it, it might not be spot on with the average, but it'll be close.But all next week starting i think on Tuesday and beyond the temps are going to be only in the 70s. ?
You did a lot of things you we're lucky to survive with a clear pool.I mean i always closed at this time ??
Exactly. Other years it was cool now. This week so far was well into the 90s. We gotta roll with the punches.this being the hottest summer on record ever we just have to acclimate and change certain things.
