Hello People I might close my pool either this Saturday OR Next-- Right now all chemicals are good- but my pH is still around 8.2- so I will be purchasing the MA to lower it as I get closer to closing . But I have been reading about Polyquat 60 on TFP and I am going to post some answers here if you would please read below:- they are from 3 different supporters-so my question is- if my chemicals are good by closing and i bring the pool to full SLAM- do I need to add the Polyquat 60- I am hoping not?
It’s been my experience that adding polyquat does lower FC a bit. When closing (October), I add polyquat and let it circulate for a day. I then bring FC back up to SLAM level then close it up and cover (solid tarp over mesh safety cover).
Yes, your FC dropped because of the Polyquat 60. I used it one year and wouldn’t do it again.
Polyquat isn’t necessary at all if all chemicals are balanced, pool is clean, water temperatures consistently below 60 degrees Fahrenheit, and FC is at SLAM-level before throwing the cover on. PQ60 eats up a lot of FC which sounds counterproductive to me — especially considering you’re instructed to close at half-SLAM if using it instead of full SLAM without it (make it make sense?!
). Closing late (even when no one can swim) and opening as early as possible are the biggest keys to opening up to crystal clear water in the spring!
This is basically what I do;
Bring FC up to SLAM.
Wait a few days for FC to drop a bit.
Add polyquat and let circulate a day.
Bring FC back up to SLAM and close/cover it up.
I close in October and open in early May. Sometimes there is still some FC at opening, sometimes not. I cover the mesh safety cover with a solid tarp (this makes a big difference in my experience). Never any algae at opening.
I must admit I’ve not tried forgoing adding polyquat at closing since what I do has resulted in an easy opening year after year (been doing this many years)
